Does anyone know how to tighten up the driver/pass mirrors? I've looked all over the mirror and cannot see any screws/torx to tighten. The passenger one seems to be doing fine.....so far.
It will vibrate just driving around. No excessive bumps or potholes needed. Any help is greatly appreciated! -Mark |
Re: Vibrating drivers mirror
What year?
if your truck is 95 or newer, you need to remove the door panel to access the bolts that hold the mirror in place.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
sorry.......its a 2004 Bravada AWD (collector edition) if that matters.
I should also mention that its not the entire mirror assembly shaking. Its only the glass that vibrates/moves. -Mark Last edited by gladesteen; 11-01-2007 at 02:36 PM. |
I don't know about that year, anybody else know?
the nylon gears are spring loaded to prevent stripping, take your thumb and press on one side of the mirror until you hear a click or two and then do the same on the top. you might be able to reseat the gears into an unworn tooth. worth a try.
