Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-31-2007, 02:12 PM
2.3L_turbo's Avatar
2.3L_turbo 2.3L_turbo is offline
Question what pound injectors do i have?
so when i bought my new motor it had blue injectors. i know that a stock 4G63 has orange injectors so they r upgraded and i dont know what pound they are. do u guys know lol
this is whats gunna happen when u see me fly by u
1990 eagle talon soon 2 be runnin
<a href="http://s228.photobucket.com/albums/e...t=100_0316.jpg" target="_blank"><img src="http://i228.photobucket.com/albums/e...m/100_0316.jpg" border="0" alt="Photobucket"></a>
mods-
K&N air filter
Crushed BOV
MBC
Bigger injecters
oh and not to forget the new JDM Motor lol
Old 10-31-2007, 03:50 PM
steviek's Avatar
steviek steviek is offline
Re: what pound injectors do i have?
we can't tell just from what colour they are.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 10-31-2007, 04:47 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Actually, you can:
210cc light tan top
240cc orange/pink top
390cc tan top
450cc blue top (95+ are black top)
EVO 4G63 injectors:
510cc yellow top
560cc red top
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 10-31-2007, 06:58 PM
2.3L_turbo's Avatar
holy crap so ur sayin i have 450 pound injectors
sweet more boost
mods-
K&N air filter
Crushed BOV
MBC
Bigger injecters
Old 10-31-2007, 07:06 PM
Testiklees
Yeah if you have any turbo model. Except for 1G Auto. They came with 390's. It's not measured in LBS, it's in CC's.
Tim
1990 Talon AWD
PTE SCM5031
Old 11-01-2007, 08:02 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Actually injectors are also measured in lbs/min. 2.3L was referring to the cc's but injectors are measured on both units.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-01-2007, 12:24 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
V8 /domestic injectors are usually in lbs, imports are almost always in CC's.
Here is a cool little injector worksheet. It can help you if you need to convert from lbs to CC's or vice versa for any reason.
http://www.rceng.com/technical.aspx
1991 GSX 2.3 Stroker
Old 11-02-2007, 11:04 PM
kjewer1 kjewer1 is offline
AF - Advisor
You can skip this post if exact numbers don't matter to you.
The problem with that and all other online calcs is that none of them take Specific Gravity into account. When converting between volume flow and mass flow you need this SG value to be included. I'm sure they just use some common value when they come up with the 10.5 number, but most DSMers use both pump gas and race gas, which are quite different.
To make an example, a stock 450cc/min injector would be a 45 lb injector on pump gas, and a 41.5 lb injector on the lightest race gas. That translates into a 3 lb/min or 30 hp difference in what those injector will support.
If you need rough numbers, the online calcs will work. But if you need exact numbers to verify injector flow or airflow meter or WBO2 accuracy, take the fuel's SG into account in your calculations.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
