Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-30-2007, 11:04 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Porting the bitch!
Porting the turbo first thing in the morning *by first thing, i mean like 10:30 or 11am* (its 11pm Tuesday night) and Wednesday (tomorrow) I’m hitting it full force! Any words of advice? Tips? Hints? Wish me luck!
Old 10-30-2007, 11:11 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Porting the bitch!
Take your time and wear safty glasses. And dont f* up anything.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-30-2007, 11:18 PM
Black99GST's Avatar
HAHA! Have the day off tomorrow (and its holloween) so time... got 24 hours! safty glasses are a must! as for F*ing things up... DUH! thanks! anyone else have useful tips? (these are VERY usefull!) i'm using an air dremel and a carbide tip...
Old 10-30-2007, 11:31 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Can't stress enough to TAKE YOUR TIME AND GO SLOW!!! Remember, you cannot replace material that you have taken too much off of. Port, check, measure, port, check, measure, port, check, measure. By the time you're done you should have almost as much time in measuring and checking it over as you have actual porting time. Good luck and let us know how it turns out.
Did I say go slow?
95 Talon TSI AWD
97 Eclipse GST
Old 10-30-2007, 11:38 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah, turbos are by far the biggest bitch to port, atleast on my 16g there was so much extra material to take out. Just go slow and check vfaq.com and/or tuners articles for porting advice.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-31-2007, 04:07 PM
Black99GST's Avatar
well... i woke up this morning, and as planed i went straight to the garage… everything was going good, drained the coolant, oil, and removed the oil/water lines from the turbo, down pipe, ok so I got up and started to remove the Manifold2turbo bolts… well that wasn’t going to happen WTF? I got my breaker bar, and really gave some force… the bolt cracks loose! Awesome! One by one I break them loose, everything was GREAT! Perfect, no problems… until I realized that I had broken every one of the 4 bolts… F*ck! Well, I figured they would come out with a little PB blaster and some vice grips, so I continued working, and got the turbo out (after removing the ENTIRE manifold) unbolted the O2 housing… and removed the Exhaust housing from the rest of the turbo… well, hours went by, I used PB, Vice grips, Propane torch, and every combination of those three tools you can think of… the bolts wont budge. I’m waiting for a quote from slowboyracing.com to see what they will charge me for the port job, 34mm wastegate mod, and removal of the 4 broken studs… here’s some pictures of the F*ckage…
Then! I noticed that my wastegate cant open a full 90*… could this be a contributing factor to boost creep? Pics:
Sorry for the HUGE pics, but i want everyone to see how bad they really are stuck... look how tworn up the bolts are, the one that is real bad, i cut like that to give the Vice grips somewhere flat to get a bit on... but man, i've been fighting this thing like hell!
Old 10-31-2007, 05:44 PM
Heat the piss out of them (glowing red hot) and they should pop loose, you'll probably need more than a handheld torch though, you'll need a commercial size one that gets hotter than shit. That's shitty though.
95 Talon TSI AWD
97 Eclipse GST
Old 10-31-2007, 06:38 PM
Black99GST's Avatar
By Commercial, you mean like oxy-fuel??
Old 10-31-2007, 07:39 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Probably a bit too late. But before I removed my exhaust mani and t-25 I soaked the bolts in PB Blaster twice a day for 3 days before I attempted to remove them. When I did go to remove them they came out with no trouble at all. Im not sure what kind of down time you can afford (depends on if you have a dd) but I would try soaking them in pb blaster for a couple days.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-01-2007, 07:52 AM
Holset powered 420a
Damnit I told you not to break anything.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-01-2007, 10:47 AM
Thor06's Avatar
Jizzed In My Pants
No wastegates open to 90*, not stock MHI ones anyway. Its more like 45*.
Old 11-01-2007, 11:11 AM
Black99GST's Avatar
not like i ment to!
i did...
Old 11-01-2007, 12:34 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I've never had to result to heating anyting to remove a bolt. I am curious and this may seem like a semi-noob question. But what truely is the benefit of heating up the bolt before trying to remove it? Wouldn't heating it make the bolt harder to extract, by virtue that things expand when heated up and contract when cooled down?
1991 GSX 2.3 Stroker
Old 11-01-2007, 12:37 PM
Thor06's Avatar
Jizzed In My Pants
This is true, but they should be heating and contracting at basically the same rate since they are both ferrous materials. I think the real benefits to heating is it cracks the corrosion and shit apart, but this is just my best guess.
Old 11-01-2007, 05:20 PM
stprasinz stprasinz is offline
You wouldn't heat the bolt.. Youd heat the material the bolt is locked into.. It allows that material to expand... And the heat breaks up the rust crud etc... And as for the propane torch your turbo probably saw a bit more heat (ok alot more) on those hard boost runs you did before you ever decided enough wasn't enough.....
good luck
