Old 10-30-2007, 02:56 PM
homegrowm311 homegrowm311 is offline
Time to replace the fuel pump
I have a 2001 Silverado with a 5.3L showing some sings of a failing fuel pump, specifically it's hard to start and the fuel gauge jumps all over the place. I know there are two different main types, with and without evap emissions. How can you tell which one your truck needs?
Thanks,
Kris
Old 10-30-2007, 05:27 PM
rjeffery rjeffery is offline
Re: Time to replace the fuel pump
Look under your truck in front of the gas tank. If there is a rectangular black box with fuel lines running into and out of it, that is the evap system. If you have the evap system, you need the evap compatible pump.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 10-30-2007, 05:39 PM
I checked and sure enough I have the evap box in front of the fuel tank. Thanks for the help.
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I would also take a look at the fuel pressure regulator. I wouldn't be surprised if it needs to be replaced as well.
*Under Construction - New sig to debut*
Old 10-31-2007, 10:44 AM
No problem. Good luck with the install, and don't forget to replace your fuel filter while you're at it.
