Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-30-2007, 01:08 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
PVC Pipe Moisture
I was under the hood yesterday and noticed moisture on the PVC pipe, before the actual valve (coming off VC). I wiped it off and it's a yellowish color, but doesn't smell like oil though. When the car sat for month from the accident it also built up moisture too. I used heater hose when I had to replace it. Any ideas on why it's wet?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-01-2007, 04:35 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: PVC Pipe Moisture
You mean the PCV valve? Not sure why it's wet, has it been raining lately and under the hood will just collect some moisture?
95 Talon TSI AWD
97 Eclipse GST
Old 11-02-2007, 06:20 PM
david-b's Avatar
Dave is THAT guy
Ya I always get the ordering messed up... PVC, PCV... all the same.
Nope been dry. Its just wet on the hose. Nothing else is wet or anything. Does the heater hose absorb at all?
I mean it was soaked when the car didn't even move for a month. So I don't know. Garage is dry.
75 Monte Carlo
Old 11-02-2007, 07:05 PM
PCV - Positve Crankcase Vent
Wild guess. There was moisture inside the hose from before and then when it sat for awhile it started to absorb through the hose? I have no idea. Take apart the hose and see if it's wet inside. Probably not something you need to worry about though.
95 Talon TSI AWD
97 Eclipse GST
