Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-30-2007, 11:32 AM
truxs1 truxs1 is offline
2003 explorer sport trac fuel problem
My check engine light came on. Then after a few days the check fuel cap light came on. The code said air leak.
I changed the fuel cap no joy.
I checked all lines going from fuel tank no joy.
Any ideas?
Old 10-30-2007, 11:52 AM
denisb denisb is offline
Re: 2003 explorer sport trac fuel problem
By all lines do you mean vacume/vapour return lines? Could be a bad vapour management valve (I beleive that's what they are called) they regulate the vapours going back to your gas tank neck and are part of the emission control. You can send smog into the system to check for leaks if your mechanic shop is equiped for it.
Old 10-30-2007, 10:14 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Welcome to the forum!
What is the exact code number that you found? There are quite a few emissions-related codes for air leaks, so knowing the exact code will help hone in on the real issue or problem area.
If you don't have the full code, swing by a local chain auto parts store. Most will read the codes at no cost, but be sure to get the actual code (in the form of P1234) rather than the salesperson's interpretation of the code.
-Rod
Old 10-31-2007, 06:03 PM
The codes are
0455 evap large leak
0457 gas cap off
I all ready replaced the gas cap with no change.
Old 10-31-2007, 10:04 PM
shorod's Avatar
SHO No Mo
The code P0455 is EVAP Control System Leak Detected (No Purge Flow or Large Leak). According to the factory service manual, this can be casued by:
  • After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
  • Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
  • EVAP canister purge valve stuck closed
  • Damaged EVAP canister
  • Damaged or missing fuel filler cap
  • Insufficient fuel filler cap installation
  • Loose fuel vapor hose/tube connections to EVAP system components
  • Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
  • Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
  • Canister vent (CV) solenoid stuck open
  • Mechanically inoperative fuel tank pressure (FTP) sensor
The code P0457 EVAP Control System Leak Detected (Fuel filler cap loose/off). According to the service manual, this can be casued by:
  • Fuel filler cap not installed on refueling (storing continous memory DTC) and "Check Fuel Cap" light may also be illuminated
  • Fuel filler cap missing, loose, or cross-threaded.
-Rod
