Old 10-30-2007, 10:49 AM
Grubdub Grubdub is offline
question
I'm thinking of purcaseing a 1995 2WD silverado, with a 350, towing package, ext cab ect.
my big question is , how well can two wheel drive get me though the winter?
i live in michigan.
also, whats steps are needed to put in a new EGR valve?
thanks a bunch.
Old 10-30-2007, 05:48 PM
JustJCarr73's Avatar
JustJCarr73 JustJCarr73 is offline
Send a message via AIM to JustJCarr73
Re: question
not very well... rear wheel drive with no weight on the wheels... Put weight in the back and add some good tires and you might be allright, but 4x4 is def the best way to go.
'97 Chevy K1500 - "Big Blue"
-Edelbrock Shorty Headers
-MagnaFlow High Flow Catalytic Converters
-Flowmaster American Thunder Dual Split Cat-Back Exhaust
-Upgraded 8mm Ignition Wires
-Bosch Fusion Platinum IR Plugs
-Pioneer Head Unit w/ iPod Adapter
-Rockford Fosgate 6.5" (Doors)
-Pioneer 4x6" (B-Pillar)
-35" B.F. Goodrich A/T KO
'77 MGB Roadster Convertible
-It runs good enough for now...
Old 10-30-2007, 07:04 PM
Re: question
worse than my camaro?
Old 10-30-2007, 07:32 PM
abaird abaird is offline
Re: question
Probably not as bad as a camaro. They can be a little ridiculous on snow and ice. I will never own a 2wd truck because being stuck in a slippery parking spot is enough for me to justify buying a 4wd.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 10-30-2007, 07:51 PM
rhandwor rhandwor is offline
Re: question
I used a brace that goes across the back of the truck and put full five gallon hydraulic oil cans filled with used oil all across the back. Make sure they are dirty or they might steal them. They sell braces at northern equipment they look like a chrome brace you would put in the basement but are thinner. You can remove the bags when you have a warm spell.
The egr usually has two bolts and a vacuum hose on it just do the job with the engine off.
Old 10-30-2007, 09:10 PM
cartman0223 cartman0223 is offline
Re: question
i would install a differential locker. i added one to my 97 k1500 4wd with "open" differential and rarely use the 4wd in winter. the truck performs just as well without extra weight and i no longer add any.
i bought the "POWERTRAX No-Slip Traction System" over 4 years ago and i have had no problems at all.
i also live in michigan... northern lower
Old 10-31-2007, 12:42 AM
2000CAYukon 2000CAYukon is offline
Re: question
Since it has the towing package, it might already have the G80 locker RPO Option (see SPID Sticker in the glove box). See if both wheels spin when you loose traction (dirt or wet road).
If both wheels spin, good snow tires and some weight over the rear diff (sand bags, they also make a special tank that holds water), it will as good as your Camaro (or better).
If only one wheel spins, a locking diff is a must.
//2000CAYukon
Old 10-31-2007, 05:09 AM
Re: question
thanks a bunch guys
Old 10-31-2007, 06:51 AM
Frankp87 Frankp87 is offline
Re: question
I took old truck tire inner tubes, cut them in half and filled them with sand, sealed the ends by folding over and heating it with torch until soft, then clamped between two pieces of steel to set the seam. They lay over the wheel wells very good and are easy to carry and store. I've used them for well over 7 years now and still holding up good.
Frank
Frank
1998 Silverado Z71
