Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 10-29-2007, 06:52 PM
brainsinajar's Avatar
brainsinajar brainsinajar is offline
Send a message via AIM to brainsinajar Send a message via MSN to brainsinajar
Here's the situation
Hello friends-
Been awhile. I hope all is well. So I've been kicking car ideas around for a bit and debating about whether or not I want to keep my birdy and I think I've decided yes. The only problem is:
The engine is not as happy as it once was and the tranny is knock knock knockin on heaven's door. It responds horribly to agressive acceleration, often stalling in high RPM, sort of like if you were to throw it into first gear at 80 mph. I'm afraid replacing the tranny will kill the engine. Any ideas or suggestions? I will eventually replace the engine with a more powerful block. Perhaps I should baby the transmission and do it all at once?
Thanks
Fly with the grace of an angel, strike with the heart of a demon.
Heresy grows from idleness.
Old 10-31-2007, 04:38 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Here's the situation
Repairing the transmission won't kill the engine but the loose nut behind the wheel with a heavy foot might! If you're afraid you can't control yourself then do them at the same time.
The Original 97Bird
Old 11-02-2007, 05:13 AM
Haha Don't worry, it's not that bad. Once I learned the situation I started to be good. My biggest probelm is driving on big highways. I'm actually a pretty calm driver for the most part, but in a situation where the road is a two way two lane road and I'm stuck behind a truck going 25 mph under the limit and the limit is 60, I can't really pass cause the transmission sort of does it's own thing. But thanks for the input. I'll be good =)
Old 11-26-2007, 03:53 PM
Would it be cheaper in the long run to replace the block and transmission as a single clip as opposed to doing them seperately? Thanks.
Old 11-26-2007, 06:34 PM
97Bird's Avatar
If you are paying someone to install them, it would be cheaper to do them at the same time.
The Original 97Bird
Old 11-26-2007, 08:11 PM
rhandwor rhandwor is offline
Are you getting both at the junk yard or putting in two rebuilt units in the car. Its makes a difference. Its hard to recover your money on a vehicle this age.
