Old 10-29-2007, 05:28 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
My Shift Lever Rattles...
Something new has started....
My shift lever rattles.
If I put my hand on it, it stops rattling.
Any suggestions on what to do about that?
Old 10-29-2007, 08:34 PM
ammcf1 ammcf1 is offline
Re: My Shift Lever Rattles...
Sounds like a personal problem to me... (hee, hee) Sorry, I had to say that.
I don't know what to do about it...
Old 10-29-2007, 09:47 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
its probably the plastic bushings in one end of the shifter rod that runs from the shifter to the transmission. either that or one of the bolts is loose. should be able to get a new shifter rod from wrecking yard or the bushings from a dealer. its also possible something in the shifter itself. should be able to remove the boot and take a look at it and check under car and make sure rod isn't to close to exhaust
Old 10-30-2007, 06:15 PM
flashlight flashlight is offline
I would have to agree with Crvett69 as I just replaced the whole shifter rod mount on mine, because it had broken. AS soon as I got a new one in there it didn't rattle or move excessively anymore.
Old 11-18-2009, 04:27 PM
DOCTORBILL's Avatar
Geo Metro Lover
My shifter stopped rattling for a couple of years, but now it is really going ape.
Don't know why it stopped or why it is starting up again...it is my '93 Metro AKA "The Phoenix".
I will look under the shift lever, but I don't remember how to lift it up.
What holds it in place?
The weather is crappy so it may be a while before I can get under the car.
Been losing power since winter weather started (gas plus ethanol?) so now I am Seafoaming the
gas and I'll pour some down the Throttle Body until the engine dies and let it set overnight.
I wouldn't doubt that the EGR is full of carbon - as well as the TB EGR gallery.
DoctorBill
PS - wouldn't any used assembly be pretty much as worn out as mine probably is ?
Old 11-18-2009, 06:13 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
You got to get the car safe on stands and get under the car and you will see the long rod and there are bushings where it connects to the bottom of the shift lever and bushings on the trans connection. Check for looseness.
Old 01-14-2010, 01:40 PM
DOCTORBILL's Avatar
Geo Metro Lover
Finally, I had to go to a shop to have the rattle looked at.
Too rainy, muddy, windy and cold for me to do it on my driveway.
Yes - loose bushings.
Had the mechanic cut some plastic from a Clear Plastic Safeway Salad
package and wrap it around the link bolt to take up the space.
I am pretty sure I cannot buy new plastic bushings anywhere.
No rattles now - and no worries.
DoctorBill
Old 01-14-2010, 09:55 PM
New bushings are available at the dealer for like $5.00 each.
Old 01-15-2010, 04:37 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Originally Posted by DOCTORBILL View Post
Been losing power since winter weather started (gas plus ethanol?) so now I am Seafoaming the gas and I'll pour some down the Throttle Body until the engine dies and let it set overnight.
This has me worried. The loose bushings allow the rattle, but the engine is the genesis of the vibration. Often when guys say their shifter shakes all over, it ends up being a burnt valve.
Clogged EGR will not effect the car's performance in any way, it might even run a little bit better with the EGR clogged. It's bad for the engine in the long run, and it's bad for emissions, but it's not going to cause any driveablility issues.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 01-15-2010, 03:58 PM
DOCTORBILL's Avatar
Geo Metro Lover
Johnny Mullet
"New bushings are available at the dealer for like $5.00 each."
Are these available via NAPA or Schucks ?
What is the part name ?
Usually just calling it the right name is half the battle !
DoctorBill
Old 01-15-2010, 07:43 PM
DOCTORBILL, I will go to work tomorrow and get the GM part # from the 4 bushings I picked up for my Metro and the wife's Metro. You can then call up any GM dealer and they can order them up for you. Please give me the weekend to get this info since I am going out of town for the weekend.
