Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-29-2007, 03:34 PM
marquis00 marquis00 is offline
rough idle
I have a 01 Explorer Sport(4.0L SOHC)with 93,500 miles on it and it idles rough. I have changed out the fuel filter,air filter, plug wires, spark plugs, ignition coil(resistance on the secondary coil was out of limits) egr valve, dpfe valve, egr solenoid, fuel injector cleaner every 1500 to 3000 miles, new muffler, cleaned out the idle control valve(also checked the resistance on the solenoid and it was fine). i even hooked a vacuum gage to it and it is reading 18 inches in Hg. Has anybody had a similar problem? any help would be great.
Old 10-29-2007, 06:43 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: rough idle
get the charging system fixed then see what the idle does.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-06-2007, 07:48 PM
Re: rough idle
well ichanged out the tps sensor. the rpm has gone up and and the rough idle has gone away to some degree. still idles a little rough, but iam thinking it could be bad motor mounts, i will check them this week.
Old 11-06-2007, 07:49 PM
Re: rough idle
oh charging system was fine
