Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 10-29-2007, 03:01 PM
George G. George G. is offline
Code- P0420
I'm hoping someone can help me. I've searched this forum and found different answers for this code. I took my moms car to get checked out at Autozone and it came up with code p0420. I'm trying to find out which sensor I should replace for her. I don't know where Bank 1 is. I'm going to hope it's an O2 sensor but which one? Before or after the cat converter?
Another problem I noticed while driving it there, when I accelerate from a stop, there's a bad shudder/vibration for about 1 second and then it drives fine. It almost feels like a bad clutch on a manual trans but her car is an automatic. Any suggestions?
George G.
2007 Expedition EL
Old 10-31-2007, 07:48 PM
crownedroyal crownedroyal is offline
Re: Code- P0420
Sounds like you may need a new cat. converter. You can try and change the o2 sensor after the converter but i think you will find that the code reappears.
Old 11-16-2007, 01:42 AM
alphalanos alphalanos is offline
Re: Code- P0420
If I remember right bank 1 is the O2 sensor in the header. Change your tranny fluid?
96 EJ6. Future home of boosted B18C1.
Old 11-18-2007, 04:49 AM
derekryans derekryans is offline
Re: Code- P0420
dude i had those problems. bank 1 apparently is the one after the cat. from what i've heard. i ended up replacing the cat. then a 1457 code popped up. so i replaced the charcoal canister. i would start with the oxygen sensor, since that's what i did. umm...oxygensensors.com i found really good priced ones. but then again im a newbie so you might have more experience with where to find even cheaper ones. good luck! i had a hell of a ride with mine to finally get it to riding good
