| Let's get Technical! Discussion for hardcore in-depth motor heads! |
b16a2 swap in a 96 civic ex
I'm looking at doing a b16a2 swap into my 96 civic ex. Will I be able to use the original mounts, shift linkages, and axles that came with the b16 swap or do I have to get custom "swap" parts? Thanks!
if it hurts, hit it til it stops hurting
Re: b16a2 swap in a 96 civic ex
You will need B series mounts and new shift linkage as well as a new ECU to run it...IIRC
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
Im not sure on that question...the mounts may not bolt up to your car because the B16 may have come from a different chassis, or the mount may have been designed differently for the B series rather than the D. If you're not getting answers fast enough here, which you're obviously not, you should check on Honda-tech. There is an entire section devoted to engine swaps and the like....check it out sometime
www.honda-tech.com
