Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 10-29-2007, 09:19 AM
tomvid tomvid is offline
97 Wrangler SE 2.5
Blower fan for heater only works on highest setting. Any ideas?
Its getting cold here in Cleveland, OH. Please help!
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
Old 10-29-2007, 09:51 AM
2000izusu 2000izusu is offline
Re: 97 Wrangler SE 2.5
most likely the blower motor resistor in the blower housing. shouldn't be more than 20 dollars. mike
here is a link to same problem!
http://www.automotiveforums.com/vbul...motor+resistor
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 11-05-2007, 03:54 PM
For the record. It was the Blower motor resister. Cheapest I could find it was at the dealer for 48.00. Thanks for the help!!!
Old 11-06-2007, 11:04 AM
if the resistor goes out in short order again, the brushes in your blower motor are probably out of spec causing the motor to draw more current! just fyi if it takes a dump again! mike
2000 rodeo SOLD
Old 12-02-2007, 02:44 PM
jeep wrangler-nw1 jeep wrangler-nw1 is offline
i had seem similar issues. You got the part at the dealer for just 48$... that sounds pretty good. I didnt find it that cheap
Jeep Fan in NW
my jeep wrangler blog
http://www.jeepwrangler.com
