Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-28-2007, 09:42 PM
2.3L_turbo's Avatar
2.3L_turbo 2.3L_turbo is offline
Question My Car Died???????
k so here is wat happened i was drivin around when all of a sudden my car just died at first i thought my it was the battery but after i got the thing home i found out that the fuel pump had lost power does any body know if there is a ground that is not vissible because of the motor or if it could just be the wireing in the car the car is a 1990 eagle talon. thanks for all our help
this is whats gunna happen when u see me fly by u
1990 eagle talon soon 2 be runnin
<a href="http://s228.photobucket.com/albums/e...t=100_0316.jpg" target="_blank"><img src="http://i228.photobucket.com/albums/e...m/100_0316.jpg" border="0" alt="Photobucket"></a>
mods-
K&N air filter
Crushed BOV
MBC
Bigger injecters
oh and not to forget the new JDM Motor lol
Old 10-28-2007, 10:00 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: My Car Died???????
Check fuses, I doubt the fuel pump went bad. They usally only go bad when you first start the car. Check all the wiring and test out everything.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-20-2007, 10:31 AM
2.3L_turbo's Avatar
ok well im strating to really get mad is there a wire in the motor bay thats not hooked up if so wat does it look like and were does it go lol
mods-
K&N air filter
Crushed BOV
MBC
Bigger injecters
Old 11-20-2007, 12:25 PM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
I hate to sound like an ass, but did you check the connections on the rear of the tank in front of the rear bumper?
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 11-20-2007, 01:22 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
If its a 1990, it might have an ass load of dust, dirt, etc. that might be giving you a bad connection.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-20-2007, 01:52 PM
You positive the problem is that your pump is cutting out? Or are you just experencing some kind of fuel loss that could be due to a leaky connecting or bad fuel rail/injector seal. Check all four injectors, fuel filter connections, fuel lines. Only do this after you check the connections on the back of the tank tho lol.
93 Eagle Talon Tsi
Rebuild TTD:
Old 11-24-2007, 01:09 AM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
yes, check simple things first.
like check the fuses hanging off the battery terminal. I know when I....
ok...regretably....
put a nEoN KiT on my car, I drilled a screw into the fuel power line, which made the line short out and blow the fuse, so the fuel pump wasnt getting power.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 01-28-2008, 11:45 PM
addict_cb7 addict_cb7 is offline
where is the fuse for the fuel pump?
Old 01-29-2008, 12:19 AM
and is the fuel filter located at the fuel pump?
and is the fuel fi
Old 01-29-2008, 06:51 AM
Holset powered 420a
Unless you tell us what car you have we cant help you.
All of your fuses are in the fuse boxes, just look on the covers and find out which one it it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-29-2008, 07:13 AM
JoeShmoe's Avatar
Man, this thread is old. Did the OP ever figure it out?
