Old 10-28-2007, 09:26 PM
buickultra2000 buickultra2000 is offline
Ultra 2000 Supercharger
1. How do I remove the large gray cover over the engine?
2. Can I check the supercharger oil from the top or do I need to access it from under the car?
Thank you.
BigC
Old 10-29-2007, 12:34 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Ultra 2000 Supercharger
At the center of the cover where you see the molded lines is a fastener like a wingnut. Turn counterclockwise. Then unscrew counterclockwise the oil filler extension located towards the front of the cover.
The inspection/fill plug to check supercharger oil level is located on the snout and done from the top. Use a 3/16 Allen wrench to remove the inspection plug. The oil level should be at the bottom of the threads. If low use only GM supercharger oil PN: 12345982. See pic below.
Timeslip 08/12/06
AF Community Guidelines
Old 11-13-2007, 06:09 PM
Smile Re: Ultra 2000 Supercharger
BNAYLOR,
Thank you very much!!
BigC
