Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-28-2007, 07:30 PM
L1lflip L1lflip is offline
Electrical problem
i have a 88 prelude and it keeps blowing my hazard light fuse and my relay, I looked around for any bad ground but cant find anything. Any1 no whats wrong???????
Old 03-12-2008, 02:38 PM
ianwright07 ianwright07 is offline
Re: Electrical problem
check for a short to ground not a bad ground its almost always the cause. if you know how to use an ohm meter disconnect the power wire from the power source then put the red lead to the power wire and the black lead to a good known ground.if there is some continuity between the two begin tracing the wire until you find the spot where the wire is pinched or has rubbed thru and is touching a ground.
