Old 10-28-2007, 05:40 PM
B3565 B3565 is offline
Unhappy T&C tail lights continually on
After changing the cig/acc fuse on our 2000 T&C, the tail lights now stay on. Any suggestions?
Old 10-29-2007, 03:54 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: T&C tail lights continually on
First, are you sure you don't mean brake lights and not tail lights? If you apply the brakes do the rear parking lights get brighter or do they stay the same intensity? Why did you change the fuse? Were any lights out?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-29-2007, 05:05 PM
Bear Bear is offline
Concur with is it tail lights or brake lights, if brake lights then the stop light switch (under dash and activated by brake pedal arm) is probably the culprit. How bout the cruise control, does it work, again activated/deactivated by stop light switch. Switch is easy to change and runs about $12.00 from many auto part stores.
Old 10-29-2007, 06:26 PM
mike12493 mike12493 is offline
today I came home to see the TAIL LIGHTS stuck on and the car shut down. What is happening?
Old 10-29-2007, 06:35 PM
wayneo69 wayneo69 is offline
unplug the brake lite switch and see if the lights are off if they are replace the brakelite switch after unplugging the brake lite switch ande lights are still on check the headlite switch and the multifunction switch
Old 10-31-2007, 09:49 AM
vgb14 vgb14 is offline
Just fyi - this happened to me a couple of times when I shut down the car with my foot on the brakes. Just restarting the car and shutting it down cleared the problem.
Old 11-02-2007, 08:54 PM
Its the brake lights. I noticed a slight spark when I insert the brakelight fuse. Sorry for late respose. I've been on the road.....
Old 11-03-2007, 01:01 PM
Re: T&C brake lights continually on
The stoplight switch was the problem. $12 bucks at Advance for the part and 10 min to replace. Piece of cake. Thanks to all...
