Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-28-2007, 04:13 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Plug Wire Question
Would 10mm plug wires be more of an overkill then a benefit? Should i just go with 8mm or 8.5's instead?
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 10-28-2007, 05:48 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: Plug Wire Question
I think with your setup 10mm would not be necasary. I'm running 8.5s on my car. There are some guys with high HP dsms that even run stock wires. If I was you I wouldn't spend all that extra money if I didn't have to.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 10-28-2007, 05:51 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Are 10mm wires any bigger than the 8.5mm? I know the outside is but is the actuall core any bigger?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-28-2007, 06:58 PM
It doesnt tell the core size, i only asked because i have never seen 10mm wires before... http://www.slowboyracing.com/estore/...cat=531&page=1
Do you guys have opinions on what brand to go with...
Under The Hood:
Interior:
Old 10-28-2007, 09:21 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Stockers will do just fine for you, or anything of the like. No need for oversized wires on a n/t.
95 Talon TSI AWD
97 Eclipse GST
Old 10-28-2007, 11:21 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Unless you upgrade your coil pack at the same time, stock or similarly sized aftermarket are just fine. I decided to go with 10.3mm wires because it was recommended with the stronger coil that I got atleast 8.5mm wires, so I went big and it turned out well. Much of the extra size is due to increased shielding.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-29-2007, 02:20 PM
Thanks a lot guys, ill probably just stay stock then, the stock wires are brand new, they were just replaced before i bought the car.
Under The Hood:
Interior:
