Go Back   Automotive Forums Car Chat > Mitsubishi > Montero/Shogun/Pajero
Old 10-28-2007, 11:51 AM
shutin shutin is offline
code help P0120
hate for my first post to be a 'help me' one.... but here goes. '97 montero flashing a p0120 throttle\pedal position sensor\switch 'A' circuit malfunction. where do i start?
thanks
Old 01-28-2008, 10:00 PM
ru4el4 ru4el4 is offline
Re: code help P0120
Unplug the connector to the throttle position sensor and examine it for any green corrosion. Plug it back in. Use a scan tool to clear the code. Check the adjustment of the throttle cable. So far the last time I saw a po120 code, it also had a Map sensor code with it. PO115? I think. The Montero Sport would bog down and stall when you apply gas above idle. It really turned out to be
the VAF or MAF sensor malfunction. It did not even leave a code!!! I unplugged the sensor and then the vehicle ran properly!!! The next day we got a new VAF or MAF sensor and the customer is now happy.
Old 01-29-2008, 05:28 AM
Re: code help P0120
thank you very much, i'm having a tough time even finding a book for this. the '97 seems to have fallen thru the cracks in "haynes\Chilton" area
Old 06-03-2008, 01:29 PM
Re: code help P0120
i took the plug apart and cleaned...no difference. so i'll order a new one. i'm also getting a p1600 'serial connection w\ tcm malfunction'
