Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-28-2007, 01:16 AM
Walsh44 Walsh44 is offline
99 P71 Stalling
I have a 99' P71 and its constantly stalling. Usually it is in the morning or after it has been sitting for some time. I used fuel injector cleaner twice and used some carb cleaner and it hasn't cured the problem. Does anyone have any suggestions or ideas as to what this problem is?
Thank you.
Old 10-28-2007, 07:13 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 99 P71 Stalling
Arte you talking about when you first start it with a cold engine? Starts and dies, starts and dies?? If you put foot on gas pedal, does it run then? If yes, replace the Idle Speed Control Motor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-29-2007, 12:02 PM
Re: 99 P71 Stalling
Yes, that's exactly what I'm talking about. Is replacing the Idle Speed Control Motor a big project?
Thanks!
Old 10-29-2007, 02:34 PM
way2old's Avatar
TOKEN HILLBILLY
Re: 99 P71 Stalling
It is a simple repair to do. There is one electrical connection, one hose, and 2 8 mm bolts to remove. It Is located almost center of the engine behind the throttle body. Here is a picture, yours may vary in looks, but it is same procedure. There also may be a gasket that you will need. SOme had gaskets and some didn't.
Old 10-29-2007, 06:09 PM
Thumbs up Re: 99 P71 Stalling
Thanks alot!!!
