Old 12-01-2002, 08:44 AM
Vric's Avatar
Vric Vric is offline
another scrap model....
Thanks to testor again to scrap my Supra Body... will never buy testor spraycan again....
So how to get rid of this paint and primer ? I don't have Castrol Super clean, so I need help ? Do I need to let it try then sand it for 18 hours in a row or there is an other solution (other than take the body and trow it away)
Testor Gray primer (sux big time)
Model master (testor) Pure White
:flamer: TESTOR:apuke:
Old 12-01-2002, 08:49 AM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
:smoka: CSC is the best although ive never used iut, i just use easy off oven cleaner:alien2:
:frog: put the model inyto a plastic tub praythe easy off all around the model and wwait a good 10 hours or less but not much less, then take a toothbrush and scrub the paint away:frog:
Rui
(modeling) = Click Here
Old 12-01-2002, 08:56 AM
Vric's Avatar
dry or fresh paint ?
right now it's fresh (just scrap the body 10 minute ago) do I need to wait a couple of hour to let it dry ?
Old 12-01-2002, 09:09 AM
well i wouild wait a while to let it dry a little then use the easy off:sun:
Rui
Old 12-01-2002, 09:15 AM
Vric's Avatar
ok I have tryd with a small part (interior bumper) and it seem to work.. at least, I see the primer through the white paint... I will pray to not scrap the kit
Old 12-01-2002, 09:41 AM
:silly2: and i think i should add: use rubber glovves and a mask or respirtor, that easy off is a killer, also i will take off all of the paint but probably not all of the primer:silly2:
Rui
Old 12-01-2002, 10:08 AM
Vric's Avatar
Originally posted by fullbloodchop01
[Bwill take off all of the paint but probably not all of the primer:silly2: [/b]
true.. cant get out the damn primer !
paint geting out easy in 1 hour...
djmr2's Avatar
djmr2 djmr2 is offline
vric. get some castrol super clean at Walmart.
it's the easiest to get off enamel... very fast too..
make sure u wear gloves
Old 12-01-2002, 10:25 AM
Vric's Avatar
thanks... i thing i will wait and when it will be dry, I will sand it.. will take more time, but i'm a bit out of money (xmas)
Will cover with Tamiya Primer and Tamiya paint after... should not be a problem
Old 12-01-2002, 01:38 PM
Vric's Avatar
after 5 hours of work with easy off and a toothbrush, the body is safe !
need to sand it a bit but it should be ok.. thanks for the help
I just got some tamiya paint from my hobbyshop... hope it will be better
Old 12-01-2002, 02:34 PM
maxhogblom maxhogblom is offline
Banned
Send a message via AIM to maxhogblom
:frog:
Old 12-01-2002, 02:43 PM
primera man's Avatar
"P-Man"
At least you saved it.
Does the wordTAMIYA ring a bell
View All My Models Here.
Old 12-01-2002, 02:57 PM
Vric's Avatar
yes master
