Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 10-26-2007, 10:06 PM
pithi69 pithi69 is offline
90' Deville Alternator wiring help!
Hey, okay so my alternator was bad, changed it a month later and I can't remember where the wires go. The 3 that are held together on the back of the alternator were pretty straight forward (i think) but the other 3 wires I can't remember where they go. One wire looks like a ground which I think goes between one of the nuts that hold the alternator. And the other two wires i'm pretty sure they go on the stud on the back of the alternator. I tried this but the car has no charge. Does anybody know if this is correct, or if I am doing anything wrong? Please and thanks.
Old 11-04-2007, 02:25 AM
Re: 90' Deville Alternator wiring help!
bump: does anybody know?
Old 11-06-2007, 11:50 AM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Have you checked your battery? If your battery has a dead cell then it will not hold a charge.
Old 11-06-2007, 04:15 PM
The battery is good. But could the wires for the alternator make that much of a difference if one isn't in the correct place? I'm starting to think the alternator guy didn't rebuild it properly.
Old 11-06-2007, 04:20 PM
350Z_Fan 350Z_Fan is offline
Maybe. I think there might be a kink in the engine or something.
Old 11-08-2007, 06:50 PM
Uhhhhhh what?
Old 11-08-2007, 07:02 PM
maxwedge maxwedge is offline
A990 racer
Ignore it!!!
Old 11-10-2007, 02:37 PM
Okay well, the three plugs that are held together all show a 12 volt reading. The 3 other wires, im sure two of them are grounds and the 3rd wire comes from the harness. The wire from the harness does not show any voltage. The prong on the back of the alternator is for the Battery since it says "Batt." I took a wire from the positive side of the battery to the alternator and the alternator started to make a whistling noise and the wire got really hot. Could the alternator still be screwed, or something else wrong with the car like a computer problem? Thanks.
Old 11-16-2007, 07:41 PM
cant anybody that has the same car open the hood and check for me please?
