Old 10-26-2007, 10:17 PM
stephenc1 stephenc1 is offline
Brake Changeover
I recently changed my 05 silverado rear brakes from drum to disk.
Now the new brakes are stuck on. Is there a pressure sensor that needs changing to release the calipers ? checked emergency brake they are not engaged.
Old 10-27-2007, 11:32 AM
weo38 weo38 is offline
Re: Brake Changeover
Did you bleed the system after reinstalling? You may have air in the lines.
2009 Z-71 ECSB
2007 Yamaha Grizzly 700 FI
Old 10-29-2007, 10:22 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Air in the lines would keep the pistons from compressing not opening.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 10-29-2007, 06:53 PM
tykrz's Avatar
tykrz tykrz is offline
Calipers seized on for whatever reason, either faulty part or installation. Air in the brake systme makes for a spongy brake pedal which will go to the floor.. To properly bleed the system, you need a GM scan tool to cycle the abs.
Old 10-29-2007, 10:39 PM
Problem solved. It was 2 brand new faulty calipers.
Thanks for your input.
Old 10-30-2007, 11:50 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Can you tell a difference between the drum and rotor rear brakes? I mean when you are braking that is.
