Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-26-2007, 06:06 PM
Alexander II Alexander II is offline
Install Cam shaft
How would i go about installing performance cam shaft?
Old 10-26-2007, 06:12 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Install Cam shaft
Get a haynes manual, it'll tell you everything you need to know including torque specs.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-28-2007, 03:17 PM
ned032002's Avatar
ned032002 ned032002 is offline
Are cams considered a plug and play sort of part, I mean besides all the bolts and stuff but is all you need to do i pull the other one out and put a new one in? And how do you go about chooseing what cams to go with?
Old 10-28-2007, 09:24 PM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
Not neccesarily "plug and play" takes a little more than that...but not to darn hard. Except for timing can be a pain. Rock the crowers lol
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 10-28-2007, 09:28 PM
Thor06's Avatar
Jizzed In My Pants
Some cams are plug and play some are not. The center line of the lobe is not always right on with aftermarket camshafts. For example, I believe it is like 4 degrees off on the HKS cams and they need to be "degreed" whereas its right on with my FP 2 cams. This is why people need adjustable cam gears. Another thing is the agressiveness of the cam. Some dont need valve springs and retainers, some do. Also, if you are going agressive enough, some cams have so much lift that you need special valve seals.
As for picking which ones, the first thing I would look at is A) how much power you want and B) what your budget is. Also, engine displacement is something that needs to be taken into consideration. A given camshaft, say an HKS 272, is sort of "milded out" when it gets into a stroker or 2.4 motor.
In my personal opinion, HKS 264 or equivilent cams are wasted money. If you are going to go through the trouble of getting cams, I would personally go with a set of 272's for a 2.0L for a street or street/strip setup and I would for sure go atleast 280's on a track only car. The FP 2's (aka Comp 101200's) are similar to HKS 272 cams, but the FP's have a bit more top end and are only $430 a set straight from FP, I think I got mine of eBay for like $350 compared to the HKS cams that are $350 per cam. If you had a stroker or a 2.4, in my opinion you should have atleast 272's preferably 280's for a street/strip car and if you were crazy and had a track only car you can get some fuckin 288's. It should also be noted that FP has the X version of each of its cams which is made specifically for the 100mm stroke engines.
Old 10-28-2007, 10:24 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
If you're doing it as a first-step bolt on mod, think twice about it. There are way more cost-effective mods you can do before even starting to look at putting in some cams.
95 Talon TSI AWD
97 Eclipse GST
