Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-26-2007, 04:19 PM
scotts96gt scotts96gt is offline
cams
how can i determine what cams i have? i was given a set or mustang cams that are supposedly PI but im not entirely sure.. SO before i go through the trouble of swapping them out is there any numbers stamped on the cam that i could cross reference?
Old 11-12-2007, 06:07 AM
noitall noitall is offline
Re: cams
Mic the lobes and compare it to your non-pi cam in your 96---pi cams have a LOT more lift--watchout for piston contact. If the cam gear is pressed on it's possible you have Winsor PI cams. Contact Anderson Ford Motorsport.com--they invented a tool to change the cams in a romeo engine without removing the front cover-and would know the part numbers used in Mustang GT's(there are several). I have a Winsor engine so I had to remove the front cover when I swapped in Crower stage 2 cams. If I can get to my stock cams(they are in the attic) I will see if a part number is on them and post it here. Good Luck!!
Old 11-12-2007, 08:30 AM
Re: cams
bearing surface 1.062 driver side cam lobe 1&2 2.184 2.175 part number left cam xL3E 6c255 ABC under that number 0114400
2000 F150
2006 Fusion SEL
2000 Mustang GT
Old 11-12-2007, 12:17 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: cams
What are you calling a "Winsor engine"? If Windsor is what you mean then I am afraid you are mistaken. You mention "Winsor PI" and cam's as in more than one. You are talking about a modular or over head cam engine. The Ford Windsor engine family does not have any modular design engines. They are all single cam pushrod motors. I'm not sure what motor you have but I'm guessing a 4.6 which is not a Windsor (260, 289, 302, 351).
1969 Cougar
357w & TKO - 475hp
Old 11-12-2007, 04:52 PM
Re: cams
If you have a W in your mustang gt vin you have a engine from the romeo plant--if you have an X you have a engine from the winsor plant--I have a winsor engine--it was in the Mustang from 99 to mid 2001--that's why their are 2 types of SOHC cam covers available from BBK and others as well as 2 types of Patriot Peerformance heads etc. 4.6L 281 cu.in.
2000 F150
2006 Fusion SEL
2000 Mustang GT
Old 11-19-2007, 05:48 PM
Re: cams
Yeah, it looks like i have a set of windsor Pi cams. I unfortunaly wasnt paying attention when i purchased them but i didnt want the pressed on cam gears so i went out and bought a set of romeo cams so i can bolt them in like the pre 99 mustangs. thanks for all the help
