Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-25-2007, 11:33 PM
jisaacson jisaacson is offline
Vents won't work...
I have an '02 Explorer with a 6 cyl. engine, 170,000 miles. I am having a problem in that I cannot get the dash vents to function. The blower works fine on either A/C or heat, but I cannot get the air to blow out of the dash vents. The defrost vents, foot vents, and small side window vents seem to work fine.
One suspicion would be a vacuum line has become disconnected, but I'm looking for possibilities. If it is a vacuum line, where should I look to see if that is the problem? Any other thoughts on what might be wrong?
Old 10-26-2007, 12:42 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Vents won't work...
Vacuum line would be a good suspect if you have the manual HVAC controls. If you have the EATC, the problem may be electrical, but the EATC has self diagnostics.
-Rod
