Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-25-2007, 08:23 PM
poormillionaire2 poormillionaire2 is offline
Security Light
Another problem...my car won't start and the security light is flashing when I try and start it. This has happened to me one other time, and ever since then, the security light has stayed lit on my dash, but has always started. Last night, I noticed that my security went off for the first time in a year and a half. Thought nothing of it, then tonight I go to drive it, turn the key, and nothing, but the security light is flashing. So, we take my girlfriend's car. Come back and try it again, nothing. Get the spare ignition key that I just had made (and verified that it worked) and nothing. I clean my original key and try it and nothing. I can't figure it out and the owner's manual doesn't say much about it. Any suggestions or ideas?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 10-25-2007, 11:18 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Security Light
VATS.. time to bypass.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 10-25-2007, 11:28 PM
Re: Security Light
I did a search after I posted the first question and found a link to a plug-and-play bypass cable. Do you think that is a good deal, or should I rig something up myself? But electrical stuff is my least favorite thing about cars.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 10-25-2007, 11:40 PM
blindeyed's Avatar
eBay aDdict™
Re: Security Light
If you can get a plug and play one then I would go with that. But I believe you're still going to have to do some wire cutting and splicing. Also, I think you have to measure the Ohm resistance of your key to make sure you get the right resistor(s) for the bypass.
- Jason
Old 10-26-2007, 08:02 AM
Re: Security Light
Yeah, on the page it said that I would have to go to a dealer and check to see which number my key is. Funny thing is that I just went to the dealer a week ago to get an extra ignition key and saw the number on the reader...but I better go back and double-check to make sure I don't order the wrong one.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 10-26-2007, 09:31 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Security Light
Poor-son,
enighten the situation, use ohm-meter.
Old 10-26-2007, 03:46 PM
Re: Security Light
Ok, just I just noticed something...the security light blinks when I try to start it, not stay on. I looked in the manual, and it said that the blinking indicates that the key pellet is weak or something. But I've got a new back-up key and that doesn't even work.
And what should I test with the ohm-meter? And how do I use it? I hate electrical shit.
I NEED TO START MY CAR!
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 10-26-2007, 04:00 PM
wrightz28's Avatar
Re: Security Light
Clean the area around the lock cylinder too!
With a ohm meter you measure the resistance instilled in the pellet.
Old 10-26-2007, 04:20 PM
Re: Security Light
I just sprayed some compressed air in the ignition to try and clean it out...and nothing. This car is a pain in the ass.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 10-26-2007, 04:26 PM
wrightz28's Avatar
Re: Security Light
Nono, clean it, not give it a blow job. Mostly the ears, like your mother always told you, don't forget to clean behind the ears.
Old 10-27-2007, 07:26 AM
CamaroRS92 CamaroRS92 is offline
Re: Security Light
You should also verify that the wires from the ignition lock cylinder are not broken. This is a very common occurance with VATS .
Locate the 2 tiny wires at the base of the steering column usually orange and white or blue and white. Unplug from the harness insert your key into the ignition cylinder then check the ohm resistance between the 2 wire terminals where you unplugged it. No reading = broken wires - Replace lock cylinder.
Old 10-27-2007, 01:10 PM
Re: Security Light
I guess I'll try it. Don't know when I'll have time, maybe Monday after school. I can't stand this car anymore.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 10-28-2007, 08:58 PM
5046adam 5046adam is offline
Re: Security Light
first check the ignition wires from the battery cus mine was doing the same shit the light was flashing but it was the pos. wire on mine. if it's not that then it is vats. The easiest and cheapest way to fix it is to use the pellet from ur key. Lay in on the counter and push it out carefully with a srewdriver or somthing. then find the two wires from the vats, unplug the connecter and cut it from the side on the steering column as high as u can-more wire on the plug the better. Then solder the pellet to the wires, tape it up and plug it back in and thats it. Yes u can use a resister from radio shack but then your car will be doing the shit a year from now. You have two keyes so try it and dont ever worry about it again. p.s. if later on u want to fix it the right way(replacing the lock cylinder) u still can cus u cut the wire on the steering column side -a new one comes with a plug
Old 10-30-2007, 12:38 AM
Re: Security Light
Had a few minutes to spare today and got into the car a little bit. First thing I did was jack up the car and check the starter. But from the way the car is in the driveway and where the jack was located on the car, I couldn't get a clear angle. But I snaked my hand up there and checked/wiggled both wire connections. Seemed ok. I may get under there later and pull the starter and reinstall it because I did that the last time the security light did this and that seemed to help. Then I pulled the kick-panel under the steering column to check those wires. Well, its slightly more complicated now because of the alarm wiring. Damn, there is a shit-load of wires. This may be tougher than I thought. Wiggled a bunch of wires around to see if that would help...nada. I'll do a more thorough check later when I have more time.
So, how difficult is it to replace the ignition lock cylinder? Do I have to pull the entire steering column, or can it be done with the column intact?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 10-30-2007, 08:54 AM
wrightz28's Avatar
Re: Security Light
column stays, but I would do a lot of studying up on disabling air bags.
