| Off-Topic Talk about anything other than cars. |
help with testing ignition coil
So I am trying to test the primary resistance of my ignition coil but not sure if I'm testing the right part. The pictures in Haynes are drawings and not very helpful. Basically, I am getting a resistance reading of 1.5 ohms for which the manual says should be 0.70 to 0.90. In the picture below, its the connector to the left of the two spark plug wires. thanks in advance.
http://halfdead.atspace.com/
1995 Mitsubishi Eclipse GSX |
Re: help with testing ignition coil
looks like you got the right part, maybe is just bad.
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
I'd help you right now, but I'm wayyyy too drunk to work my way through Mitchell. I'll post instructions tomorrow at noonish. I tihnk i've posted them somewhere here befor though so try do a serach.
This should help you out some.
![]() Primary Coil Resistance Measure the resistance between connector terminal 3 (power) and each coil terminal. Measuring point: No. 1 - No. 4 cylinder side coil; 2-3 No. 2 - No. 3 cylinder side coil; 1-3 Standard value: 0.70 - 0.86 Ohm ![]() Secondary Coil Resistance Measure the resistance between coil high Voltage terminals. Measuring point: No. 1 - No. 4 cylinder side coil; A No. 2 - No. 3 cylinder side coil; B Standard value: 11.3 - 15.3 K Ohm
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Thanks for the replies. Those are the drawings that are in my chilton's as well. I'm still getting those ohm numbers so looks like I've got a bad coil. It's a little surprising since the car is not riding that bad. But thanks again.
Just an update, I measured the secondary coil resistance and I'm getting about 13.5 kohms which is in reference range. So I guess having a bad primary coil resistance is enough to create idling problems. Any thoughts would be appreciated.
1995 Mitsubishi Eclipse GSX Last edited by volsmd99; 10-27-2007 at 02:26 PM. |
