Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-25-2007, 07:08 PM
solar-eclipse solar-eclipse is offline
1989 2.8L firebird cam??
im looking for a new performance cam for my friends 2.8L firebird... its a 89, where could i find one?? i hope to give it to him on his birthday.. october 29th.
New out the box
1996 eagle talon tsi awd 78 MILES.... ON THE BODY!!
redemtion is a must.
Rip; 2005 subaru wrx sti.
Finally up on my feet, and working on 2 cars.
Old 10-25-2007, 11:31 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: 1989 2.8L firebird cam??
comp cams available through summit racing 16-233-4. youll also need lifters 802-12, valve spring 980-12 and possibly keepers and retainers
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-27-2007, 10:36 AM
MrPbody MrPbody is offline
AF -Advisor
The Comp offering looks okay. Too bad you don't have a bit more time. Maybe you could give him a gift certificate for a Comp cam, and have them grind you up an XE256H for the little 6.
As for the springs, we use small block "performance" springs in the 2.8/3.1 iron heads with a mild cam. They "drop in", and cost very little (about $2 each). Be sure to use the stamped shield under the spring, or it will "dance". What's commonly refered to as the "Z/28" spring.
Another VERY good choice is Melling MTC-5. It sports a little more duration than the Comp, but not quite as much lift. In a 3.1, it makes GREAT power to about 5,100 RPM.
Comp also makes "Magnum" rockers, in both 1.5 and 1.6 ratio for the little 6. 1.5s with the Comp cam, 1.6s with the Melling, and you'll get as much from the cam as it can offer. NOTE: SBC rockers DO NOT FIT, even though they appear the same, they're "standard" and the 60 degree V6s are "metric" (dimensionally).
Jim
Old 11-14-2007, 05:19 PM
vortecman's Avatar
vortecman vortecman is offline
whats the most power you can get out of a N/A 2.8? (swapping heads & cams and such)
Old 11-14-2007, 08:15 PM
damn man idn, prolly about 155 at the wheels, not alot... maybe not even that.
New out the box
Old 11-14-2007, 08:22 PM
vortecman's Avatar
well, those guys up there acted like it was a popular thing to mod these cars, so i thought they might be putting up some respectable numbers. i'd call 155 RWHP respectable though... i have one of those old cars, but it probablly wouldn't hold up to an aggressive cam. i've thought about getting a new 2.8 put in it to save gas.
Old 11-14-2007, 08:24 PM
Ha, the 2.8 is the worst engine choice my man... It is not a good modding car, there is almost no aftermarket, the engine is a down right dog.. Do you have one??? if so pm me
New out the box
Old 11-14-2007, 08:31 PM
vortecman's Avatar
no, but it would be cheap! (vs a 3.4 swap). i need a vehicle that would get better MPGs than my truck. and i already have this old car....
