Old 10-25-2007, 04:19 PM
new2mitsu new2mitsu is offline
No Spark, need help quickish
ok, so i know theres been alot of threads on this topic lately but i need to figure this out. i am getting no spark, i know its not the plugs, coils or wires. what i need know is... what is the easiest way to tell wether its the PTU or the ECU or the CAS? im having alotta trouble diagnosing this one. it ran superbly last night, then when i go out to head to school this morning, no spark... kinda weird to happen all the sudden dont you think? any help would be greatly appreciated. Thanks in advance guys.
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 10-25-2007, 04:50 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: No Spark, need help quickish
if you had a Service Manual then you could easily test the PTU with a multimeter/voltmeter. i highly suggest you get a service manual. you can find them on ebay for about $20. be sure to get the SERVICE manual, not the owner's manual (which is useless).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-25-2007, 06:27 PM
Igovert500's Avatar
blue + red light magnet
http://www.stealth316.com/2-pwrtransunit.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-25-2007, 06:35 PM
squirllee squirllee is offline
try finding a 98 vr-4 's internals for the 6 speed manual transmission yeesh
Old 10-25-2007, 08:22 PM
so, what does that have to do with anything?
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 10-25-2007, 10:33 PM
ok, well its not the PTU, so, do you think it could be the CAS or the ECU?
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 10-25-2007, 11:37 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Two words
New Bee
Old 10-26-2007, 03:48 PM
ok, so i swapped the PTU last night, same thing... then i got my datalogger, and tried to run trouble codes with the ignition switch in the on position, and it was telling me there was a Serial Communication Error, and after checking all conections 3 times over, i concluded that everything was quite well hooked up. so im guessing i could have fried the ECU? it is a 93 afterall. is this a possibility?
Also, will my JDM vr4 ECU plug right up to my fed spec vr4 wire harness? thanks guys
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
