Old 10-25-2007, 02:26 PM
triplethreattt triplethreattt is offline
Chassis Lubrication?!?!?!
1998 Grand Voyager
Can someone tell me where the lubrication points are underneath this van? I have looked and looked...but not finding them, and I'm thinking that a good lube job is in order.
It doesn't have anything in my Chilton's Bible, other than to "Crawl under the vehicle and lubricate the components (take plenty of rags)". The illustration is showing me the items I'll need to do a good lube job, but nothing to tell me WHERE I need to lube.
I used to have a Ford Ranger, and it's suspension was a sealed contraption that didn't require lube, and someone told me this van was the same, but I'm thinking that it's not.
Pics would be helpful, if there's a DIY site out there that has some...All advice is always appreciated.
Thanks in advance!!!
08 Honda Fit - 45,000 miles
08 Honda Odyssey - 32000 miles
97 Lexus ES300 - 175,000 miles
*Gone, but still in the family*
98 Gr. Voyager 200,000 miles (the last 100K thanks to these forums)
May she R.I.P.
***89 Mazda 929 180,612 miles***
Old 10-25-2007, 06:10 PM
Bear Bear is offline
Re: Chassis Lubrication?!?!?!
The reason they are difficult to find is there are no grease (Zerk) fittings on your car.
Old 10-25-2007, 07:22 PM
vgb14 vgb14 is offline
If you want, you can install zerks onto the lower ball joints because they will eventually run dry. Just unscrew the plug from each ball joint and replace with a 1/4 - 28 size zerk fitting, preferably one with a 45 or 65 degree angle, so you don't have to remove the wheel to add grease to them later.
Old 10-25-2007, 08:29 PM
great information guys...thank you!
so...no zerk fittings...but the Chilton's guide says to grease "the components"...
LOL.
May she R.I.P.
Old 10-26-2007, 01:26 AM
fallen4shell fallen4shell is offline
IMHO, Chilton repair manuals aren't worth the paper they're printed on. Go to www.alldatadiy.com and purchase a subscription for your car....MUCH MUCH MUCH more specific and useful information than you will ever find in one of those little DIY chilton's manuals.
