Old 10-25-2007, 02:08 PM
Ccorbitt Ccorbitt is offline
Unhappy Engine Problems
I have a 2001 Chev. Silverado. I turned on the truck and the engine turned over, but then very quickly died. I turned it on again pressed the gas and the engine would rev as long as I held the pedal dawn a little. I was able to drive home, but at any intersection where I took my foot of the gas the engine would fade and die. I would have to restart the truck and get my foot to the pedal. Ideas?
Old 10-25-2007, 02:20 PM
MikePhC MikePhC is offline
Re: Engine Problems
You may have water in the gas. Put a bottle of gas line antifreeze in the tank and see if that helps with the stalling.
Old 10-25-2007, 04:47 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
Re: Engine Problems
That is a sign of a TPS (throttle position sensor) or the like.
pull the vacuum line off of your Fuel pressure regulator, if fuel comes out, change the regulator.
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 01-04-2008, 08:28 PM
rockwood84 rockwood84 is offline
Re: Engine Problems
Old 01-06-2008, 11:07 AM
AaronIROCZ AaronIROCZ is offline
Re: Engine Problems
My 2002 silverado did the exact same thing, pulled into a store and it ran fine, went to start it back up and I noticed my bat light was lit and tried to press the accelerator and I got nothing, I had to hold the gas at every intersection till I got home and then it started to idle on its own.
Old 01-06-2008, 04:29 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Engine Problems
Check the IAC. Both the actuator and the passage. Take the IAC off and watch the plunger as you turn the key on and off. It should move. Also make sure the passage isn't blocked.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
