| Exterior and Wheels This is the place for all exterior wheel modifcations. |
DIY Vented Hood
well i'm planning to buy a 90-92 galant hood off the junk yard or someplace and vent it. just wondering was tools i need to cut through that metal. I'm also planning to remove the hood reinforcements also too. if you guys havent felt how heavy a GVR4 hood is, its gotta be at least 30+ pounds maybe even heaveir. I am NOT going to rice it out the hood, just need help on how to cut the metal without ruining the hood realllly bad. thanks!
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
Re: DIY Vented Hood
Why not just buy a carbon fiber hood if your worried about weight.
I have seen a few articles about venting a hood, let me see if I can find them.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: DIY Vented Hood
i saw one on tuners a while ago, for a 2g, it looked good but i'm not man enough to cut my own hood.
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
Re: DIY Vented Hood
Here you go..
http://www.dsmtuners.com/forums/showthread.php?t=220112 http://www.dsmtuners.com/forums/showthread.php?t=109404 A member on 2gnt also has put a vent in his stock hood thats looks badass, but there is no write up on it. *EDIT* - http://www.2gnt.com/www/corbin/sig7.jpg
Re: DIY Vented Hood
Re: DIY Vented Hood
Yea those do look real purtty. At work I work with sheet metal all day and would say if you plan on cutting anny bigger of vents than the ones shown here to go to the local rental house and rent some power shears. They make one hell of a lot nicer cut than the scissors. Although I suppose if you plan on dremeling/grinding and maybe repainting it doesnt matter. But yea I used the shears to put in my sunroof. Do not get center cut sheers thought...they will scratch the hell out of your paint and they suck.
Live From The Great State of Hockey 93 Eagle Talon Tsi Rebuild TTD: Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security |
Re: DIY Vented Hood
I wouldn't suggest cutting the hood braces out, they're there for a reason and without them your hood won't hold up for very long at all, it'll start to sag and bow in.
Re: DIY Vented Hood
thanks a bunch guys!! im thinking about leaving the hood braces in now. most likely i'll try to make my hood look like an Evo III hood.
Re: DIY Vented Hood
that one is pointless for you. you would need to put it on the right side of the car. hes got it there to get cooler air. the TB is on the left side of a 420a unless you just want it for looks.
![]() 96 GS - 5 Speed-Sold 1998 Ford F-150 XLT 4X4 |
Re: DIY Vented Hood
It would still help to bring cold air under the hood and remove some heat.
Re: DIY Vented Hood
I am considering doing the third one...The hood supports on the 1g's doesnt have a symetrical patern in any way so the 2nd link would be alot of work and it would tamper with the integrity of the hood. As would the first link. But it looks like the third link would fit nicely between the hood brace "webing."
