Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-25-2007, 08:06 AM
soto 95 gsx soto 95 gsx is offline
What you think starting problems...
The car starts fine if you jump the car from the battery to the starter but by turning the key and pressing clutch I get nothing. its a 95 GSX, It has a new starter,new battery, and new cables. I think it is either clutch start switch or starter relay. I can check the clutch start switch by just unplugging it but what about the starter relay where is it on this car.
Old 10-25-2007, 10:06 AM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
Re: What you think starting problems...
Behind the radio I believe
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 10-25-2007, 12:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It is behind the radio. There should be 2 relays back there, the one on the left is for the door locks and the right one is the starter relay.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-25-2007, 09:09 PM
nop alredy cheked it but ok now that you tell me that which one is it, the small one or the big one? because i have the small one on the left and there is where i actually jump it to start the car
Old 10-25-2007, 10:12 PM
Holset powered 420a
Its should be on the right side. But looks like its the smaller relay.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-25-2007, 10:15 PM
Holset powered 420a
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-26-2007, 09:57 PM
My relays are backwards the starter relay(smaller relay) is on the left and door lock on the right, I put a new starter relay in and it still does not start. If I take out the relay and take the top left terminal of the connector and bridge it to the bottom right terminal it will start with the key but by putting the new relay in, it won't start. Is there something Im missing or forgetting to do? So now I have a new Starter, new battery, new cables and new relay, but still no starting!!!
Old 10-27-2007, 11:07 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Check your clutch switch. By jumping across the connector, you went right from the ignition hot wire to the starter wire, which is why it would start. The only other wire that runs to the relay is the clutch switch, which is connected to the hot wire from the ignition.
Disconnect clutch pedal position switch. Clutch pedal position switch connector is located at clutch pedal. Depress and release clutch pedal position switch. Using ohmmeter, check continuity between clutch pedal position switch terminals. If continuity exists with clutch pedal position switch depressed and does not exist with switch released, switch is okay. Replace if necessary.
95 Talon TSI AWD
97 Eclipse GST
Old 10-28-2007, 01:05 PM
Was there a previous owner of the car? Sound like there was some wiring work done. But, you did say you got a new relay right?
93 Eagle Talon Tsi
Rebuild TTD:
