Old 10-24-2007, 10:15 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Car Running!!
After a month of trying to get the fuel line back and upgrading to SS and ordering wrong parts... I finally got everything in today and installed. I don't have any pics, but it's SS line with blue/red fittings. Original I know. Plus they're scratched up and covered in Teflon paste. I took her for a test drive and not a single leak! This was the first time being able to hit the gas since the accident. So first time without A/C and the CF hood, better radiator and such. I love it.
Idle did kinda suck. I'm thinking because the ECU been unplugged for months that all the setting were whipped clean and the SAFC was trying to do stuff while the car was trying to reprogram itself. Idling like a v8 for awhile. Adjusted fuel up a little, and then was idling at 2k until I came to a complete stop. Everything is plugged in so I'm not sure. Still going to drive and let it reprogram.
I missed her mucho!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-24-2007, 10:22 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Car Running!!
nice job man, i miss mine too, it's been over a month.
post some pics, i'd like to like to see, i've been thinking on upgrading to SS lines too
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 10-24-2007, 10:33 PM
david-b's Avatar
Dave is THAT guy
Re: Car Running!!
I'll get some tomorrow. It was pitch black outside and cold by the time I was done here. Damn winter.
75 Monte Carlo
Old 10-24-2007, 11:21 PM
Re: Car Running!!
i hear you man, i'm 2 states from you, right now i come home from work at 5pm and it gets dark like arround 6:30-7pm now.
-MODS-
Old 10-25-2007, 09:01 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Car Running!!
About time you got that thing running right. +1 for pics
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-25-2007, 11:08 AM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
Re: Car Running!!
Congrats manhopefully the reving pans out for you
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 10-25-2007, 12:07 PM
david-b's Avatar
Dave is THAT guy
Re: Car Running!!
I think it should get fixed. Just have to drive it again. Also have to check some wires. When I did the head swap a wire loom with the TPS and IAC wires was touching the EGR pipe and melts the loom and some insulator and was shorting out, causing my idle to be way high. Just have to make sure those are out of way again. Probably should fix those one day.
And of course next problem... exhaust rattles even worse now. WTF!
75 Monte Carlo
Old 10-26-2007, 11:53 AM
Holset powered 420a
Re: Car Running!!
What part of the exhaust rattles? Is it hitting something? I just took my EGR pipe off and made some block off plates. That damn thing almost melted all the way through my amp power cable. I do get a CEL but I can live with that.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-26-2007, 11:56 AM
david-b's Avatar
Dave is THAT guy
Re: Car Running!!
It's by the cat. I think its the actual heat shield underneath welded onto the chassis. It's annoying.
75 Monte Carlo
Old 10-26-2007, 12:17 PM
Holset powered 420a
Re: Car Running!!
You just need to get under there and use some force. You have to show it whose boss.. lol
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-26-2007, 12:43 PM
david-b's Avatar
Dave is THAT guy
Re: Car Running!!
Ya, but to what? I believe it's the heat shield hitting the car. The exhaust is clear from everything. It gets close around the first curve going toward the wheel but I got header wrap around that section. Where the noise is coming from there is no touch-age action of exhaust pipe. So I don't know where to begin with that then just taking off the exhaust and pulling the heat shield.
75 Monte Carlo
Old 10-26-2007, 01:25 PM
Holset powered 420a
Re: Car Running!!
Does it rattle when the car is just running or when you hit bumps in the road? You should be able to get under there and beat on a few things and find it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-26-2007, 02:13 PM
Re: Car Running!!
AH high tech DSM fixes...lol...mine had a horibble rattling problem too, but all i did was retighten the ties holding the exhaust onto the car
93 Eagle Talon Tsi
Rebuild TTD:
Old 10-26-2007, 02:18 PM
david-b's Avatar
Dave is THAT guy
Re: Car Running!!
Again, it's not the exhaust itself. Everything is solid exhaust-wise.
It happens all the time. Bumps wouldn't be bad. I can get it to rattle at 2200rpm and then random pretty much anywhere above that. Doesn't have to be moving or anything.
75 Monte Carlo
Old 10-26-2007, 02:20 PM
Re: Car Running!!
Hm...the best thing besides eing able to poke around and find it would be mass amounts of duc tape...but thats just impractical...good luck on your search
*edit*
p.s. david_b that avatar can make grown me wet
93 Eagle Talon Tsi
Rebuild TTD:
