Old 10-24-2007, 08:47 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
engine internals
what is the max hp the stock internals can handle on the vr4 ive tried to find it and i have not been able to find the answer. im sorry if the answer is here somewhere i was just not able to find it.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 10-24-2007, 08:56 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: engine internals
It has been a while since I have read about this but I believe people have gone upwards of 700hp on stock internals. It may be much more than that now, IDK. I would reccomend changing out some internals before trying to get that much power out of them.
Old 10-24-2007, 09:39 PM
im just looking to hit about 300-350awhp, anyprobs with the internals to hit that goal? other than clutch?
Old 10-24-2007, 09:44 PM
VR43000GT's Avatar
If it is a proper setup with all the supporting mods, shouldn't be a problem.
Old 10-25-2007, 02:42 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
That's cake for the stock internals. The crank is indestructible (985awhp so far), rods are reliable 'till around 600awhp iirc, pistons as well. Just worry about the fuel.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-25-2007, 09:22 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Yeah the all famous matt monet of dynamic racing ran in the 9s with hella horsys to back it up on stock bottem end (pistons rods crank) its honestly all about the tune.. cause if you set up and running with knock constently it doesn't matter if you have forged internals or not your eventualy going to fuck your shit up.. now the forged internals can take a little bit more of a beating so if your tune gets fed up for a second and you start backfireing or somthing you have a better chance that you didnt blow you engine
anyway if your only going tof 350 or so then I wouldn't worry about internals at all right now.. if is on your mind think about it this way.. save your money untill you blow your working motor.. haha
so what are your plans for the build? what mods do you already have?
Old 10-25-2007, 11:41 AM
hawk362's Avatar
hawk362 hawk362 is offline
Yeah I would just highly reccomend with any mods you do to have the car tuned properly with a SAFC, stand alone, or what ever you would prefer, take it to a performance shop and have it dyno tuned if you can, or dont feel safe tuning it yourself. As long as you supply sufficient fuel with higher boost you will be fine. Especially since you plan on staying under 500 HP, only worries are your transmission and cops....
P.S. I've seen a Eclipse GS with aftermarket GST turbo boosting 4 lbs of boost but ended up having a nasty rod knock just because his car wasn't properly tuned. It can be as simple as a bad FPR will rain on your parade.... runaround
ATX 95 Base 3000GT
Off brand intake, 3sx downpipe, test pipe, custom catback exhaust, 3sx underdrive pulley, NGK PLUGS, lamborghini doors, 18 inch black rims, limo tints, GTR HIDS, Alpine in dash dvd screen,
100 SHOT OF ZEX WET NITROUS KIT
Old 10-25-2007, 04:09 PM
well as of now my only mods are mbc at about 14psi and an intake. i look to buy a palm pilot and wires for datalogging and then a fuel pump and tune. how much hp can the stock injectors push if i have a new fuel pump? then turn up the boost on the stock turbos more untill i can afford 13g or 15g turbos. i just wanna get into the 11's or 12's. also in the future i look to get some ehaust work done, not quite sure what tho, as far as staying stock catback and doing headers and precat stuff or stock headers and precat and new catback. any sugestions? also stuff that i can do on my own bc i dont pay ppl to work on my car . whats the limit on the stock turbos? ik they can boost high but wont hold to much but whats the max they can run?
as far as transmission what do i need to watch? ive had the recall done on the transfercase, so would i just need a new clutch? what is the max the stock clutch can handle at the wheels? ik its limited to like 400hp but i wasnt sure if thats at the crank or wheels. thanks for the help every one.
Old 10-25-2007, 04:21 PM
new2mitsu new2mitsu is offline
you're injectors honestly cant handle much more than the stock injectors can
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 10-25-2007, 07:54 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Get a datalogger ASAP. Its a BAD idea to go turning up the boost with no way to monitor if you are getting knock.
Old 10-27-2007, 04:49 PM
granny_shifter's Avatar
granny_shifter granny_shifter is offline
isn't there a knock sensor already in the vr-4?
i fix things that aren't broken
Old 10-28-2007, 07:37 PM
Stealthee's Avatar
There is, but the ECU can only retard timing to save the engine to a certain point.
