Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-24-2007, 01:00 PM
shermancelmare shermancelmare is offline
94 Corolla: What to replace with new Timing Belt
Hi all,
I have a 94 Corolla with 124,000 miles and am going to replace the timing belt. What other parts should I replace? I have heard that I should also get new belts, idler pully, timing belt tensioner, water pump, and crankshaft seal. But that's a lot of parts! I am going to do it all myself.
Thanks for all posts.
Old 10-30-2007, 11:08 AM
rockwood84 rockwood84 is offline
Re: 94 Corolla: What to replace with new Timing Belt
if you diy then you will need a manual haynes or chilton for your year/make/model . it will walk you through the process and make sure it is still in time when you put the belt on. the manual either one will cost you about $20.00 and save you a couple of headaches
