Old 10-24-2007, 12:15 PM
dtownfb dtownfb is offline
Changing PCV on 3.8L engine
I have a friend of mine with a 1998 Intrigue. Where is the PCV located in the 3.8L engine?
Thanks
Old 10-24-2007, 01:25 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Changing PCV on 3.8L engine
If you are standing in front of the car, it will be on the left side of the upper intake manifold, which is the black plastic thing. There is a sensor on the left side that is held in place with a little bracket thing. This is the MAP sensor and it must be removed carefully to access the PCV valve, the bracket itself may also have to be removed, Im a little foggy there. But after you pop the MAP sensor off, you should be able to see the PCV valve.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 10-24-2007, 02:26 PM
Thanks littleHoov. that seems easy enough.
