Old 10-24-2007, 11:18 AM
doowah doowah is offline
Cool Headlight adjustment?
I have a 98 silverado Z71 4x4. Don't know how to adjust headlights. Not like the older style. Where are the adjustment screws?
Old 10-24-2007, 06:13 PM
chevymank15 chevymank15 is offline
Re: Headlight adjustment?
on my truck which is the same as yours u pop the hood and you should have two metal screws that use torque head bits to turn they should be stickin straight up and down on the the side of the headlight and one kinda centered behind it hope that helps
-Red
Old 10-24-2007, 06:14 PM
777stickman 777stickman is offline
The adjusting screws are above the lights. Takes a flashlight to find them. Look for holes in the radiator support and use the flashlight to find the adjusting screws. They have an internal torx or external hex. Don't confuse them with the small hex (5mm) pins that are sticking up above the rad support. These pins are what you remove to take the whole headlight assy out.
Not sure which adjuster does what as it's been a while, so you'll have to experiment..............Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-24-2007, 08:42 PM
Thumbs up Re: Headlight adjustment?
I wondered what those pins on top were for, thanks for the info. Will look at it in the morning. Thanks alot.runaround
