Old 10-24-2007, 10:59 AM
Igovert500's Avatar
blue + red light magnet
Electrical fun continued...
OK, electrical guys/gals, I could use some insight. Brand new batteries drain withing 3-6 days. I've swapped the alternator, alternator belt, battery, rewired the starter to fix the click click start problem. I dont know if this is related or not, but even with the relay in there, sometimes I still have the click click start problem...and my batteries are still draining after 3 days. The voltage meter on my turbo timer reads usually in teh 13V range while I'm driving...occasionally hitting 14, sometimes dipping into the 12s. Back in the day I remember it always being at 14.5
I put a multimeter in line with the negative battery cable and pulled fuses and had my boy watch to see any changes, he said he saw none, and I went through every fuse in both fusible links, and a couple stray fuses for the amp.
I think I fried the ETACS or my door lock actuator awhile back, because every so often, the door locks will just keep locking themselves, so I'm wonderin if every so often this is what is draining the battery overnight...but that doesn't happen while I'm driving, and the voltage still reads low then, so I don't think that's the main problem.
Also was suspecting the battery cables, but I tightened them up and they look good, havn't replaced them but probably will sooner or later.
Any thoughts?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-24-2007, 11:02 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Electrical fun continued...
How many amps of draw are you getting with your car off?
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 10-24-2007, 12:15 PM
AutostradaVR4 AutostradaVR4 is offline
Thats about what i get from my turbo timer too...only dipping in the 12s for a split second when i turn everything on all at once.
for the draining problem, you must have a short somewhere. My amp used to kill my battery in about a week. never figured out why, but i took it out and it stopped. I eventually just hooked up an inline switch and turned it off whenever i parked it.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-24-2007, 12:18 PM
blu3kgt blu3kgt is offline
first thing i would do is go check the alternator or the whole system... becausei had a similar problem, my alternator went out so i replaced it, it worked fine but my dash light would dim when i would come to a complete stop... so then i went to go get the altenator checked and they said it was working but it wasn't putting out enough voltage, so then i changed the alternator again and problem solved,my lights didn't dim anymore but i also did notice that my battery gauge used to always read 13.5 volts with the factory alternator, now it jumps around all the time but never goes below 12v so i have come to living with it, so short story long i am saying even though you just put a new alternator, it could be bad... also i do believe your doors locking will eventually drain the battery and the reason it stops locking when your driving is because the ignition switch is positioned to on, when it's positioned off, thats when it attempts to lock
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 10-24-2007, 04:17 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Well sounds like you have an un-fused drain. (pulling the fuses during the draw test won't locate it)
I know from experience that the doors locking themselves will kill the battery. My firebird would continually unlock itself when it rained, battery would be dead by morning. Different situation than a bad ETACS but same idea.
If you're voltage is dropping into the 12's thats a sign the alternator isn't doing its job, or the battery is preventing it from doing so. Or there's a bad connection inbetween the two. But it shouldn't kill the battery if it's only occasional.
Have you read the voltage with a voltmeter at idle?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-24-2007, 06:43 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If the alt was bad then it would contantly be reading 12V or lower. Being its reading 13V most of the time I am going to say theres a dead short somewhere.
Being NA I have a factory voltmeter. I will watch it and at times it will drop below 13V and other times be reading right below 14V. My alt is fine and my battery is fine.
If its taking a few days then I am going to say its something that goes on when the car is sitting, not charging. Otherwise it would die daily.
Old 10-25-2007, 05:30 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Igo, remind me, what did you do to fix that problem you had waaaay back? was it some short in the fuel injection harness?
you have a 96. i know a local Dallas guy who's 96 vr4 had some electrical problems, but his were ignition related. though he didn't have any battery problems, i think its valid to say that 96s have wiring issues. his problem was traced to a short in the wire for one of the coil packs (this wire branches off the main harness to the passenger strut area where you can ground it and adjust the ignition timing).
anywho, my friend Gray Haze, a technical wizard, solved the problem by wire tracing. you might send him a PM on 3Si and see if he could help or at least point you in the right direction.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-25-2007, 05:36 PM
hey yea..didnt you have a wire that was acting as both power ang ground, shorting itself out of something?
Formerly BlinkRA182
Old 10-25-2007, 06:25 PM
Igovert500's Avatar
Yeah, that was a freaking blast. That's all since been fixed. Gonna work on it more tonight, if I can muster the motivation. I have a few suspicions I want to test out.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
