Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-24-2007, 02:22 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Boost creep and DSMlink questions
So ive been struggling with boost creep ever since i went to a straight pipe my boost is set at ~17 psi but will creep to 19-20 at 5300-5600 rpm and i just put in a ported o2 (maybe its not ported enough) as a result i get crazy amount of knock at 5300-5600rpm. So ive but the fuel back to stock AFR from 5k up and taken 1 degree of timing out at 5k and 2 degrees at 5.5k. But what i dont understand is that if the boost is up so substantially why isnt the airflow going way up too Is the performance loss due to richening/retarding at what is my optimum power range worth losing the performance of putting the Cat back in? Is the boost est in DSM link very accurate, i trust my boost gauge more but can i trust the est? And my DSMlink isnt working on my vista computer should it? have they come up with an update to run dsmlink on vista? Sorry for the Essay
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 10-26-2007, 10:15 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Boost creep and DSMlink questions
The o2 housing is the least of the factors contributing to boost creep. The WG exit area of the turbine housing is the biggest offender, WG hole next, then the o2 housing. The VFAQ and my site have some info on this.
Boost est is accurate only when VE is 100%. This equates to 5500-6k rpm only, for most setups.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-28-2007, 01:25 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
does link not even open? or it wont connect to your ECU? if it opens, check the COM port for you DB9 interface, and the DSmlink software itself, and makesure they match up!
Old 10-31-2007, 01:35 AM
Kevin are you talking about the flapper hole or the area just after that thats still part of the turbo brfore it goes into the wastegate "hole"
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 10-31-2007, 03:46 AM
AF - Advisor
The WG exit area would be the area just after the flapper. The pocket in the turbine housing that the WG dumps into right before meeting the O2 housing. When you consider that the WGA can only open the flapper about 45 degrees as you look at the WG exit area, you'll know what you have to do. The WG entry area can provide some min boost reduction gains as well, but you run a risk of upsetting flow at high flow levels (potentially, I have no data to support this). I usually leave that as a last resort. So in order of importance and lowest risk, the WG exit area first, then the hole itself, then the WG entry path.
Kevin Jewer
Old 10-31-2007, 03:23 PM
thanks for the help. Guess this means im gonna have to get a ball bearing garret turbo and huge tial wastegate lol I wish
1995 GSX 2Gb bumper
Wish list:
CAMS
