Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-23-2007, 11:38 PM
2001stanggt 2001stanggt is offline
01 Gt Timing Chain ?'s Please Help
My 01 GT HAS SOME ENGINE NOISES THAT I CANT REALLY TELL WHAT IT IS THE NOISE ONLY HAPPENS YOU FIRST CRANK THE CAR AND WHEN IT WARMS UP AND ITS COMING FROM THE FRONT OF THE MOTOR AND SOMEBODY TOLD ME ITS BECAUSE THE CAR DOESNT HAVE ENOUGH BACKPRESSURE BECAUSE THE CAR HAD THE MUFFLERS CUT OFF BUT I HAVE NO IDEA WHAT COULD CAUSE THE NOISE THOUGH WILL YALL PLEASE HELP ME THANKS
Old 10-27-2007, 11:41 PM
82Stang 82Stang is offline
Re: 01 Gt Timing Chain ?'s Please Help
If you really don't know what to hear for then take it to someone who can atleast narrow it down for you. Front of engine noise can be anything.
Old 11-14-2007, 07:32 PM
noitall noitall is offline
car doesn't need back pressure(I run headers-X pipe and Magnapacks on my 00 GT-only sound from engine is injectors)---if it's a ticking sound-could be normal cycle of fuel injectors. You only running 5W20 oil? Oil pump set up for thinner oil for fuel savings-thicker oil will make oil pump work harder--need more info on noise. I even run Stg 2 cams and no problems on my 2000.
2000 F150
2006 Fusion SEL
2000 Mustang GT
