Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 10-23-2007, 09:19 PM
Ccorbitt Ccorbitt is offline
Angry Engine Problems
I have a 2001 Chev. Silverado. I turned on the truck and the engine turned over, but then very quickly died. I turned it on again pressed the gas and the engine would rev as long as I held the pedal dawn a little. I was able to drive home, but at any intersection where I took my foot of the gas the engine would fade and die. I would have to restart the truck and get my foot to the pedal. Ideas?
Old 11-04-2007, 06:37 PM
69NovaKid 69NovaKid is offline
Re: Engine Problems
The same thing happened to me in my Nova - Check your timing
Old 11-04-2007, 10:49 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Engine Problems
The timing on these engines are entirely computer controlled - there is no distributor on the V8s. The 4.3 V6 has a distributor on it, but this is also computer controlled and timing is set by the OBD system. The CMP (cam position sensor) is located within the distributor housing on these 4.3 engines.
What's likely happening is you either are out of gas, have a restricted filter or a fuel pump that's about to go tango uniform. If you're sure it has gas, obtain a fuel pressure gauge and hook it to the fuel rail on the passenger side of the intake - you will see a Schrader valve and this is the port you attach the gauge to. The pressure must be at least 55 PSI for the engine to run properly.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
