Old 10-23-2007, 04:57 PM
quinch quinch is offline
windsheild wipers stop in center of windsheild
My 98 gtp windsheild wipers stop in the center of the windsheild!
Can somebody give me the part to replace and the GM part number
thanks
Old 10-23-2007, 10:59 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: windsheild wipers stop in center of windsheild
Before replacing any parts see below:
Originally Posted by BNaylor
Basically the wipers are not going to the park position probably due to a mechanical issue with the wiper motor assembly. Common problem if you live in areas where there is alot of snow and ice.
The wiper motor has a stamped steel plate attached to it with a formed tab. Due to the weight of the snow the metal tab will bend. As a result the wipers do not sense the stop point in reverse and then park straight up.
To correct the issue you will need to remove both wiper arms and the plastic cover. The tab is located on the driver's side wiper. The tab should be at 90 degrees and can be bent back into place and form.
Timeslip 08/12/06
AF Community Guidelines
