Go Back   Automotive Forums Car Chat > Ford > Mustang > Classifieds
Classifieds The place to buy/sell/trade all of your Mustang parts
Old 10-23-2007, 01:14 PM
supralou 42 supralou 42 is offline
351 c 4bolt,4bbl heads
wts a 351c/c6 tranny REAL FORD POWER 351 Cleveland engine has less than 5000 miles.4 bolt main (Boss Cleveland) block bored 30 over, crank turned 10, reconditioned rods, block line bored, new speed pro pistons 10/1 comp,
heads are completely reworked. bronze valve guides, hardened seats, new stainless valves, comp cam springs and retainers, crane roller rockers, drilled and tapped 3/8rocker arm studs, ford push rod guide plates, comp hardened pushrods, crane cam and lifters. the biggest one crane makes for this engine. cloyes double roller chain, melling high volume oil pump, edelbrock performer intake, holley 750 dual feed vaccuum advance carb, the heads are four barrel heads, ford electronic ignition, flomaster headers full length, C6 tranny with complete tci master rebuild kit and 2800 stall converter, new starter, alternator, waterpump, new stock fuel pump, tranny cooler, new 4core modine radiator. engine sits in a 1977 ltd2 bucket seats, polished aluminum dash, floor shifter all stock from factory. aluminized exhaust tubes, rhino mufflers, new rear coil over shocks, 9inch ford rear end with 272 rear gears (highway gears), stock ford magnesium 15 inch rims(the real deal mag rims), new tires, front disc rear drum brakes. inner and outer front fenders, doors hood and trunk lid are from yuma arizona. i have $10,000.00 in the car and drivetrain. perfect for the cobra car kit builder or one HOT mustang! Car and engine can be driven home full documentation for all parts and machine work $5000.00 [email protected]
