Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 10-23-2007, 11:12 AM
kcpaintballpage kcpaintballpage is offline
t-belt ?
i got a 99 sportage with 100,000 miles on it.
I was coming down off ramp and car died.
I losen the t-belt cover and belt is not moving but it is not broke.
not moving when tring to start car.
could the teeth came off the belt?
Old 10-23-2007, 12:13 PM
inafogg inafogg is offline
Re: t-belt ?
hello!! yes it is very possible.if you have the cover off look around the
crank pulley you should be able to inspect the belt.i dont no if this car
have enough valve clearence or not(so not to bend valves)but with 100k
belt is over due!! Good Luck
Old 10-23-2007, 12:41 PM
LMP's Avatar
LMP LMP is offline
Re: t-belt ?
CLassic and overdue. Happily, this is a non interference engine hence change belt, and while you are there, idler, tensioner, coolant pump....pput everything back in place and you are on the road again.
instructions here:
http://www.geocities.com/lmp4203/kia...TimingBelt.zip
complete kits are available on e-bay key words: sportage timing belt
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
