Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 10-23-2007, 07:20 AM
mj982000 mj982000 is offline
Water pump
I just replaced the water pump on my 96 Seville, is there a certain way to put the water pump back in? Everytime I put it in (5 times so far) and get everything back together and start to put coolant in the fluid comes out the back of the water pump. Any help would be greatly appreciated.
Old 10-23-2007, 02:32 PM
maxwedge maxwedge is offline
A990 racer
Re: Water pump
Welcome to AF, out the back of the pump, how?
Old 10-23-2007, 03:08 PM
powermaster powermaster is offline
Re: Water pump
Is this a norhtstar engine?
Old 10-23-2007, 04:08 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Re: Water pump
Sure you tightened the hose clamp tight enough?
Old 10-23-2007, 08:33 PM
caddydaddy caddydaddy is offline
Re: Water pump
There's an o-ring gasket that seals the back of the pump. Are you sure that's in there and not damaged? Also, I hope you know the pump turns COUNTER CLOCKWISE into the pump housing to tighten!
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 10-23-2007, 08:35 PM
Re: Water pump
Yes, it would be...only engine available for the Seville in 1996.
2000 Cadillac STS
Old 10-24-2007, 06:20 AM
Re: Water pump
Yes, it's the Northstar motor. It leaks out the back of the water pump housing. Is there a certain spot where that different tab on the water pump goes?
Thanks for your reply's!!!
Old 10-24-2007, 04:26 PM
Re: Water pump
It doesn't mention anything about that. Are you sure the O-ring gasket is installed correctly and not ripped? So it's leaking where the belt pulley is attached, correct?
2000 Cadillac STS
Old 10-25-2007, 09:44 AM
Re: Water pump
I have re-installed the pump atleast 7 times. On the socket I purchased, it says that the tab should go in the 1 o'clock position of the housing. I went out last night and looked at a Haynes book and it says it should go at the 7o'clock position. I will try the 7 o'clock position when I get home tonight.
Thanks again
