Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 10-23-2007, 04:31 AM
HiT-TheNos420's Avatar
HiT-TheNos420 HiT-TheNos420 is offline
Exhuast Question
Been searching for the answer to this question. I have a 97 gst and want to upgrade my stock exhaust, which is also leaking. (1) I am buying a whole 3" system at once, what other parts, fittings, etc. do I need to make it everything fit and flow nice on a stock exhuast system? and (2) how difficult would it be to install it myself, with little experience.
97' Gs-t, silver, Stock intake & Aftermarket Filter /w stock MAS, 1g BOV /w stock UICP, K&N Oil Filter.....
Old 10-23-2007, 05:40 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Exhuast Question
You really don't need much else. Sometimes you may have to get a flange (like on the cat) welded on, but that's it. Any shop will do that for real cheap.
Install is easy. I did mine when I was still kinda new to all of this and just took a hack-saw to different sections. It depends on how rusty everything is too.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-23-2007, 07:03 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I had to cut mine apart also. It was so rusted there was no hope. Also use the biggest socket wrench you can find. I had to put a 3ft piece of pipe on the bolts to the cat.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-23-2007, 07:55 AM
david-b's Avatar
Dave is THAT guy
When I did mine everything got replaced, so I also took a hammer and a screw driver to beat the hell out of it (around the flex pipe) because the manifold bolts wouldn't come off. But it doesn't sound like you're going that far up. And on the turbo, they're usually easier anyways.
75 Monte Carlo
Old 10-23-2007, 08:06 AM
Holset powered 420a
Mine in all replaced now. The only bolts that are even on the exhaust are the ones that bolt up to the turbo. The rest is welded together... Damn exhaust shop
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-23-2007, 09:17 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Install isn't that bad. Are you installing the downpipe and the catback. I took my exhaust off as a whole assembly (from o2 housing to muffler) since it was rusted. Are you going to be running a cat or a test pipe? My exhaust came with all the necessary bolts and gaskets.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-26-2007, 03:16 AM
Well I did some searching on the net for a both test pipe and cat, but since I just got my smog done and my tags renewed ima go for a test pipe. And later on buy a cheap cat setup for future smog testings. I also read on these forums about EBAy exhaust systems, stainless steel, that have done people good, so i might go with one of those. I Also have an Old MaxSpeed Muffler I got when I got my first Eclipse with a 4.5" tip that i might have welded on. I dont know right now if ima do that or not.
Old 10-26-2007, 07:06 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
3" Apexi-N1 ftw. Or a custom mandrel-bent exhaust with a good muffler on the back shall work wonders for you too.
95 Talon TSI AWD
97 Eclipse GST
Old 10-26-2007, 10:51 AM
Holset powered 420a
Just go with Ebay exhaust. I dont know how much 3" cat back is but I had an exhaust shop make 2.5" for my car and it ended up costing just has much by the time I bought the muffler to. The shop did a great job but it would have been easier to just buy it online.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-26-2007, 10:52 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Agree. For a GST any e-bay exhaust is pretty good. I would look into Megan Racing for the downpipe. They are cheap as hell and great quality.
I ran an e-bay Tsudo cat back on my GST and it was great.
I think IIRC I paid about $300 or so for everything.
1991 GSX 2.3 Stroker
Old 10-27-2007, 05:17 AM
cool, thanks for the info guys. If i dont go to tahoe for my birthday next weekend i will definently be buying a new system.
