Old 11-30-2002, 06:09 PM
turbo_civic_97 turbo_civic_97 is offline
Angry I need traction!
I was wondering what I could do to get more traction to my front wheels... If I hit vtec in 2nd gear uphill, I spin like crazy. If I'm just taking off from a stoplight I spin too. I have 17's with Nitto rubber and I was thinking of getting the ground control coilovers and maybe adjustable shocks so I could set them stiffer in the rear. Will this help with the weight transfer? Does anyone know if a fiberglass speaker box will save me enough weight over my MDF box to bother with? I was also thinking about getting a LSD. Are they worth the price and hassle? thanx for your help :sun:
Old 11-30-2002, 11:03 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
getting the adjustable shocks will help with weight transfer so it will help with your traction. in my opinion lsd's are worth every penny, and i think they should be the first upgrade if your a racer. whats the point of having all that hp if you cant get traction, well thats what the lsd helps with. you could also run drag radials, that would help with traction. that pretty much all you can do with traction.
also is your car lowered now ? make sure your camber is good or else you wont have you entire tire touching, which would cause more traction lost.
Old 12-01-2002, 01:56 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
theres a place in super street thats selling clutch,flywheel and lsd for both the D16 or the B16....thinks im gonna get that next...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-01-2002, 04:25 AM
if your gonna get an lsd, you should get a quaife lsd. i hear that those have a lifetime guarentee even when used for racing.
if you get a flywheel, get an chromoly flywheel if you can afford it.
if you get a clutch then i say get a cm stage 3 or 4
Old 12-01-2002, 05:04 AM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Easy Fix!
... well.. it looks like to me you're solution would be... get rid of the Vtec.
Thats your problem.
So just smack it with a hammer a few times. That should teach it a lesson. No more annoying tire spin!
My .02 cents
Yes, I am joking.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
ABS Traction control Module (HELP) ohio45344 Park Avenue 3 01-03-2011 10:53 AM
ABS and Traction Control Lights on after Jump start jbinramona Seville 0 06-22-2010 11:11 AM
02 Rendezvous - ABS/Traction Control Issue RGrizzzz Rendezvous 2 11-25-2009 05:04 PM
8" Lift, Need Traction Bar??? Msurfpro13 Performance 1 10-27-2008 04:21 PM
need traction..... eightcylS10 Street Racing 2 08-09-2004 03:36 AM
