Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-22-2007, 10:05 PM
nick96gst nick96gst is offline
turbo kits for gst/gsx
HI i have a 96 eclipse gst, i have 3inch greddy exhaust system and blitz cold air intake, also Fic 650cc injectors with safc neo, plus boost gauge and air/fuel ratio gauge. so my question is which one of the turbo kits below is better you think i was thinking the T3/T4 turbo, i planned on getting a venom intake manifold after to.
any help would be appreciated Thanks alot
Advanced JDM Parts :: TURBO UPGRADE KIT :: MITSUBISHI :: 95 96 97 98 99 MITSUBISHI ECLIPSE GST GSX JDM SPORTS TD05 TURBO KIT /W BIG COOLER
95 96 97 98 99 MITSUBISHI ECLIPSE GST GSX JDM SPORTS TD05 TURBO KIT /W BIG COOLER #16863 Click image to zoom100% Brand New and Ready to Ship.
Intercooler Piping are CNC Machine Mandrel Bent (Jp Design)
Made From High Quality 6061 Aluminum Material with chrome finish.
Extra Thick Piping and Increased Air Flow
Blow Off Valve and Adapter Pipe Included for easy Installation.
TD05 Turbo with Included for Maximum Performance
Oil Feed Line Also Included
Most parts are bolt on but some items may require modifications. Professional installation is high recommened. Instructions are not included. Details Weight40.00 lbsPrice:$799.99
Or
95 96 97 98 99 MITSUBISHI ECLIPSE GST GSX JDM SPORTS TURBO KIT #16862 Click image to zoom100% Brand New and Ready to Ship.
Stainless Steel Manifold for Turbo Models.
Blow Off Valve Included for Aggressive Sound.
Boost Controller Included for boost adjustment.
T3/T4 Turbo with Included for Maximum Performance
Oil Feed Line and Wastegate Also Included
Most parts are bolt on but some items may require modifications. Professional installation is high recommened. Instructions are not included. Details Weight40.00 lbsPrice:$949.99
Old 10-22-2007, 11:06 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: turbo kits for gst/gsx
What kind of HP goals are you shooting for? All I can tell you is get a product that has actually been tried and proven true. Kits like that always make me leary. The intercooler, pipes, clamps and gaskets should all be pretty good to use. But I'd be picky about the turbo, BOV, and exhaust mani. Make sure the turbo(at least the 16G anyway) is an actual MHI and not some ebay POS. I've heard of Exhaust manifolds cracking too if they are cheap products. I can't really tell though on this one. I've also heard that knock off BOV's aren't very reliable, but then again just what I've heard and not what I've dealt with first hand. The most important piece is the turbo. You don't want to get cheap on that.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-22-2007, 11:40 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
if you HAVE to pick between the two, i would go with the first one... the second one you posted doesnt even know what kind of car its for... GTS/GTX WTF is that!?!?! i wouldnt get any of the above... for that kinda money you could find a BADASS kit off Extremepsi or Slowboyracing IMO, i wouldnt even waste the time looking at the "Inlarged Pictures" if they doent even know the "T" is actually an "S" as in GST/GSX...
Old 10-23-2007, 02:13 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Stay away from kits like that, buy them in pieces and make sure they're original tubos like said above. Also, an intake manifold won't do you much with just a 16g or something similiar, there are much more bang-for-the-buck mods, like cams/cam gears or something like that. Intake manifolds should be more towards the bottom of a mod list, IMHO.
95 Talon TSI AWD
97 Eclipse GST
Old 10-23-2007, 07:41 AM
ok thanks for all the help
i also had a 255 walbro fuel pump if that makes a diffrent for the turbo or not.
But I wanted to get about 400hp into my eclipse and i dont want to do a half ass job on it so thanks again for all the help
so my best bet would be to buy the parts seperate?
Old 10-23-2007, 07:52 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Yea buy the parts seperately. That way you can use the parts you like the best and also know that they will hold up and not break. Sounds like your fuel system is pretty good for now. You should go ahead and look at a 16g turbo and maybe a front mount. That should get you to a good start.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-23-2007, 06:07 PM
i really appreciated it!!
Old 10-23-2007, 07:20 PM
You're running 650's on a NEO with a 255 an no AFPR? You might want to be looking at a AFPR and possibly DSMlink, or something more adjustable than the SAFC NEO, unless they're more adjustable than a SAFC.
95 Talon TSI AWD
97 Eclipse GST
Old 10-23-2007, 10:10 PM
Black99GST's Avatar
why are you running 650s on the stock turbo anyway? when you upgraded your fuel system, what turbo did you have in mind? just stick with that, if you dont want to go cheap, get a MHI 20g w/ External gate... that would be a 400+ setup w/ support mods...
